Distributor part number question 73 - NCRS Discussion Boards
  • Charles P.
    • April 30, 2005
    • 332
    ADQ: According to the 1973 assembly manual, the distributor ASM pn# 1112098 (L-48 MT) was installed as an assembly. This was done by the engine assembly plant. Therefore my manual does not break down the individual parts by PN# within the distributor such as vacuum advance. What reference(s) is best to have for more specific PN#'s for this? Tks.
    • 43241
    Re: Distributor part number question 73
    Charles-----
    There are not that many parts in the distributor. Here they are for the GM #1112098 distributor:
    housing------GM #1851158
    seal (felt)----GM #1950569
    washer (plastic)----GM #1951099
    lubricator----GM #1852935
    mainshaft w/autocam-----GM #1870658
    drive gear------GM #1958599
    cam with weight plate----GM #1870644
    weight base button (nylon)----GM #1957329
    breaker plate-----GM #1846122
    plate retaining spring----GM #1932024
    cent. adv. weights (2)-----GM #1881371
    cent adv. springs (2)-----GM #1870640
    condenser-----GM #1932004
    breaker plate grounding lead------GM #1932002
    housing grommet------GM #1932023
    vacuum control-----GM #1973446
    rotor------GM #1971247
    primary lead (to coil)------GM #1875613
    point unit------GM #1966294
    cap------GM #1971244
    cross shaft gear (tach)-----GM #1955842
    coupling (c/s gear)------GM #1955799
    washer (c/s gear)-------GM #1956834
    The problem is that most of the above information is fairly academic. Virtually all of the above parts are long-since discontinued. The exceptions are tune up parts (cap, rotor, points, condensor) and the distributor drive gear. All other parts are gone. A few of the others may be available in the aftermarket.
    • Charles P.
      • April 30, 2005
      • 332
      Thanks Joe--page printed and inserted in my ASM manual.
