C1 water pump bolts - NCRS Discussion Boards
C1 water pump bolts
  • Michael L.
    • July 31, 2005
    • 562
    C1 water pump bolts
    Use grade 5 or 8 on water pump bolts?
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C1 water pump bolts
    Mike,
    Are you looking for the "correct" head markings? If not, then any grade 5 bolt will more than suffice. Grade 8 is overkill for that application.
    Joe
    • Michael L.
      • July 31, 2005
      • 562
      Thanks Joe, just a driver, so markings are not critical.
      Mike
        • 43237
        Mike-----
        As Joe mentions, you don't need grade 8 bolts for this application. The original installation used bolts of SAE grade 5 (GM 280-M). However, in most hardware stores there is not a great difference in price between Grade 5 and Grade 8. So, assuming that the particular hardware store you use follows this pattern and assuming that they actually carry grade 8, I would purchase grade 8.
        For my hardware store fastner acquisitions, either for a specific purpose or just for my fastner bins stock, I virtually always purchase grade 8. In this manner, the fastners are "multi-purpose"-----I can use them for just about any application.
        The only downside to grade 8 over grade 5 is price and, as I say, the price difference is usually not all that great.
        • Bernard M.
          • August 31, 1994
          • 341
          Mike, The only thing I might add is that you should definitely use grade 8 when attaching the fan to the pump.
