C2 Shifter & Linkage ? - NCRS Discussion Boards
  • Alan Drake
    getting prepared to put trans and shifter back in, however I have many extra parts for orignal set up. Need some help in finding the right parts to use again.
    Levers on Trans; Have two sets - first is marked 3-4 and 1-2 (1/4" hieght) with an "X" on the reverse side near the middle hole. Second marked same (3/16 hieght) with NO "X" on ohter side. Have four small levers for reverse with a small hole in it, all the same (no idea how I got four)
    Have two different style swivels, each are square however one is rounded on top and then transistions to the square.
    The main assemble; both have a small 1/2 circle cut out about 1 1/4" along the edge while the second has another square cut (5/8 X1/4) at 3" along the edge.
    The 1-2 and 3-4 rods,
    The long rod - have one straight with "W" marking while other has 2 bends in it.
    The short rod (both have "W" marking) - one somewhat straight other has minor upward bend Both of the short rods have the slotted fit ends - one is longer.
    Q: short/long throw - assume top hole is for long??
    JM calls for all bolts and associated linkage to be black, only the square swivels are. Any JM comments??? I can always blacken them.
    Thank you for reading all this stuff, hope somebody understands my questions.
  • Wayne M.
    • March 1, 1980
    • 6414
    Excellent GM lever & rod dwgs in Noland's Vol 2
    I assume you are looking at post-'64 because of the long/short throw holes. There were subtle changes during the C2 years.
    • Alan Drake
      Re: Excellent GM lever & rod dwgs in Noland's Vol
      Thanks Wayne - that's the answer needed. I know the descriptions I posted were not going to be the best method to find the right parts. Forgot about Nolands book. Only have one hole in correct 64 part, the numbers (1-2 3-4) are shorter for the 64 lever, which were shown in drawing.
      After I get it working again will post for finishes.
      Thanks.
