solid lifters C1 - NCRS Discussion Boards
solid lifters C1
  • John S.
    • January 1, 1998
    • 81
    solid lifters C1
    I am asking if anyone knows the specifications for adjusting solid lifters on a 1957 corvette fuel injection 283?
  • Michael K.
    • August 31, 2004
    • 170
    Re: solid lifters C1
    John,
    I adjusted my 57 2X4 to .012" intake (hot) and .018 exhaust (hot). This should apply to all models equipped with mechanical lifters.
    • Michael K.
      • August 31, 2004
      • 170
      Re: solid lifters C1 (page 2) *NM*
      • Terry D.
        • May 31, 1987
        • 2696
        John
        John Hickley and Duke Williams wrote a great article on how to set mechanical lifters cold, if you don't have access to it e-mail me and I will send you a copy. It works great and no hot oil to contend with.
          • 15692
          Suggest you (or anyone else) e-mail me to get the lastest December 2005 revision.
          • Joel Falk
            Duke,
            Does your procedure apply to the Duntov cam? My understanding was that the method described in ST-12 was sufficient for the Duntov, and your/John's method became needed for the 30-30 and LT-1.
            Cheers!
            Joel
              • 15692
              Yes, the ST-12 and '63 Corvette Shop Manual are okay for indexing as far as I know, but I have different lash specs based on measured rocker ratio behavior.
