67 A/C vacuum hoses - NCRS Discussion Boards
67 A/C vacuum hoses
  • John C.
    • January 1, 2005
    • 616
    67 A/C vacuum hoses
    While changing some A/C components on my 1967 I decided to also replace the vacuum hoses that control the hot water shutoff valve. I just received my hose kit from Paragon and the white stripe hose is a small diameter and the all black hose a large. Is this correct? The hoses on the car now are both small diameters with a reducer from large to small for the black hose near the manifold vacuum take off.
    Thanks for any help you may have.
    John
  • ken edmunds
    Re: 67 A/C vacuum hoses
    Big hose from the vac fitting into the car and connects to the vac actuator on top of the heater box, small hose connects to the actuator and runs back under the hood and connects to the heater control valve. No reducer anywhere.
    • Allan J. Wicklund
      My 67 is the same as far as your original description of hoses. Hope we here more comments! Al W.
