Re: C2- Rear deck carpet will not lay flat. - NCRS Discussion Boards
  • Matt Malloy #42289
    Ken,
    Do you glue the carpet to the pad and then the pad to the deck? Yours looks great.
    regards
    Matt
  • ken magrene #44841
    if im not mistaken - you only use the jute on floors
    • Stephen L.
      • May 31, 1984
      • 3158
      My original carpet underlayment consisted of jute, a heavy "tar-impregnated" material and then carpet. The jute was glued to the fiberglass and the "tar" material to the jute. The carpet was glued to the "tar" material.
      I purchased some repro carpet made by ACC. It doesn't fit nearly as well as the original or even some old AK stuff that it replaced. It appears to be too large. I also replaced the jute and "tar" material at the same time.
      What manu made your carpeting. I'm looking for a better fit if there is a better vendor.....
        Mine is made by ACC as well. The rear deck carpet seems just a little wide, which makes it run into the fender wells. If I hear of a superior carpet set I will let you know.
        Thanks Matt
        • Stephen L.
          • May 31, 1984
          • 3158
          That is exactly the problem I have as well as the formed wheel tub covers being too large and wrinkling. Thanks for the feedback.
