427 engine finished - NCRS Discussion Boards
427 engine finished
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12785
    427 engine finished
    I've just got my 427/435 engine finished. Any remarks?
    with kind regards,
    Rob.
    Rob.
    NCRS Software Developer
  • Mike B.
    • November 1, 2004
    • 389
    Re: 427 engine finished
    It looks so good I thought that it was a GM promotional photo.
    Now install the engine, turn the key and drive the hell out of it!
    Send an audio clip once it gets running to make us SBC guys mouths water.
    • Michael W.
      • April 1, 1997
      • 4290
      Sure doesn't look like a restamped block to me. Nice find.
      Better check the torque on the valve cover bolts, the second from the left looks a little loose.
      • Michael L.
        • July 31, 2005
        • 562
        Looks great Rob!
        • Jim T.
          • March 1, 1993
          • 5351
          Looks really nice, you work fast. Seems like you just got your 69 427 last year.
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12785
            Here the other side...
            Rob.
              • 43241
              Rob------
              Looks very good. However, where did you get that fuel pump? It's not correct, at all, for your application.
              • Michael W.
                • April 1, 1997
                • 4290
                Wow! Look at the giant crossed flag logo underneath the engine
                • Terry F.
                  • September 30, 1992
                  • 2061
                  That's a funny one Rob!
                  Hope the NCRS judges have there microscopes with them, Terry LOL
                  I had to look at it a couple of times to figure out what was going on.
                  • Rob M.
                    NCRS IT Developer
                    • January 1, 2004
                    • 12785
                    Re: That's a funny one Rob!
                    I also have a fuelie block ready for mounting!
                    Rob.
                    • Rob M.
                      NCRS IT Developer
                      • January 1, 2004
                      • 12785
                      Other side...
                      Rob.
                      • Rob M.
                        NCRS IT Developer
                        • January 1, 2004
                        • 12785
                        I'm still in doubt if I should mount one of these two into this one...
                        HAHAHA!!!
                        Rob.
                        • Terry F.
                          • 2061
                          Wonder what Joe thinks about that fuel pump. I think you need to send me a closer picture of the bolt head markings so I can give further comment. Also, the big block spark plug wire grounding straps should be two straps for one valve cover bolt. You should change that before you have it judged. Careful working on it though because I am sure those plastic bolts are easy to break off. Make sure you put atleast 1.5 millileters of oil in it be for you crank it. Get your tweezers out and pull the distributor and prime it real well with a micro primer and a miniture drill. LOL, Terry
                          • Richard S.
                            • November 1, 1994
                            • 809
                            Nice plastic models........I was just in Italy for a month and went to a classic car show in Trento......of the 200 or so cars that attended....not one Corvette....very disappointing......
                            • Sander B.
                              • March 1, 2005
                              • 499
