8" wheel - NCRS Discussion Boards
8" wheel
  • Keith B.
    • December 1, 1991
    • 397
    8" wheel
    Trying to help my brother in law with a question. Was there any chevy steel wheels 15" that were 8" wide that were not ralley wheels? What car did they come on? He is trying to use a stock look by using hubcaps (it is on a 69 11,000 mile 396 camaro) wants to keep bigger tires. Mid year wheels were all 15 x 6 that used hubcaps.
    Keith
    Keith Burmeister
    • 43221
    Re: 8" wheel
    Keith----
    There were no non-rally type 15 X 8 wheels ever used for any Chevrolet or other GM car that would fit a Chevrolet.
    • george romano
      Re: 8" wheel
      Mid 70's Chevrolet Monte Carlo Landau used a 15"X 8" wheel from the factory, but I doubt it would look good on a Camaro. The wheel was "faced" with some kind of rubber to form a series of rectangular slots, or holes for design and used a 1" wide, flat trim ring along with a spin on center cap.
      George
        • 15674
        Re: 8" wheel
        Chances are that the OE wheelcovers can be mounted to 8" Ralley wheels, if wheelcovers are what he has.
          • 43221
          Re: 8" wheel
          Duke-----
          Yes, if he uses full wheel covers, most can be mounted on a rally wheel with no problem, at all. However, if he uses the "hub cap" style wheel covers, which I think is what the intention is, the rally wheel feature will remain quite prominent.
            • 43221
            Re: 8" wheel
            George-----
            Are you sure it was 15 X 8? I can't find any wheel of this size that was ever used for a Monte Carlo or Chevelle. 15 X 7 is the largest wheel size that I can find that was used for Monte Carlo from the introduction of that model through the end of its RWD incarnation.
            • george romano
              Re: 8" wheel
              I always thought it was Joe.
              The wheel was only available with the upgraded Landau trim option. I owned a 76 with these wheels.
              Car came from the factory with GR70-15 radial tires if that halps you at all.
              George
              • Keith B.
                • December 1, 1991
                • 397
                dog dish as used in COPO *NM*
                Keith Burmeister
                  • 43221
                  Re: 8" wheel
                  George-----
                  The only "special wheel" I can find that was used for 1976 Monte Carlos was identified as "with ZJ7". "ZJ7" was a special wheel code that was likley part of the "Landau Package" you described. These were a 15 X 7 wheel that was coded "FW".
                  The tire size GR-70-15 would be fully approved for use on a 7" wide wheel so that size would not imply, at all, that an 8" wide wheel was used. With only 1 exception that I know of, 7" was the widest wheel used for pre-1980 Chevrolet cars. The only exception was Corvette which used the 8" wide wheel from 1969-82.
                  • george romano
                    Re: 8" wheel
                    Learn something new everyday!
