64' 365hp parts help (Part Numbers) - NCRS Discussion Boards
  • David D.
    • January 1, 2005
    • 416
    Looking for some help with obtaining correct part numbers (or actual parts)for 1964 327 x 365hp motor
    Air Clearner Assy
    Oil Pan Assy (including Baffle and Studs)
    Thermostat Housing
    Idler Pulley
    Exhaust Manifolds (No A/C)
    Distributor (Radio Delete)
    Chrome fuel line and Filter from Fuel pump to Holley Carb
    As always...Thanks in Advance
  • Dino L.
    • February 1, 1996
    • 694
    Re: 64' 365hp parts help (Part Numbers)
    David, Being in your shoes before, and trying to find part numbers led me to one of the best purchases I have ever made for my Corvette, right here from the NCRS, a Judging Guide as well as an assembly manual...they will answer your questions...
    Dino Lanno
      • 43238
      David-----
      Air cleaner assembly----GM #6419921 (PRODUCTION and SERVICE)
      Oil pan------GM #3820001
      Oil baffle----GM #3769768
      main cap baffle studs---- GM #3872718
      Thermostat housing---GM #3827370
      Idler pulley assembly----GM #3829191
      Exhaust manifolds----LH, GM #3846563 (cast 3846563) RH, GM #3814970 (cast 3797902)
      distributor-----GM #1111069 (w/o K-66 transistor ignition)
      GM #1111060 (with K-66)
      fuel line------GM #3854796
      fuel filter----GM #5650703 (PRODUCTION) GM #5650677 (SERVICE) AC type GF-90
      While the above are the numbers, with the exception of the main cap studs and the fuel filter, NONE of these parts remain available from GM and there are no supercessive part numbers available either. The fuel filter currently available only through the Delco parts system may not be configured/appear like the original.
      • David D.
        • January 1, 2005
        • 416
        Now that be some numbers.
        Thanks ever so much Joe
