C2-67 Cigar Lighter Elements - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    I know a 63 Casco 12V lighter element is correct for a 67. Did all C2's use the same 63 Casco element?
    I just came across a couple of elements which have no number, only Casco 12V from a 60's GM car. I tried one in my 67 and found that they work better then the repro I have now (76 Casco). Actually the barrel of the no number one is about 3/16" longer than the repro with a total length of about 1".
    I think these elements came out of the rear seat of a deluxe GM as the element coils look like they have never been used----until now.
    What have I got?
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
  • William C.
    • May 31, 1975
    • 6037
    Re: C2-67 Cigar Lighter Elements
    63 Casco 12V with the porcelin ring behind the element is the one to have.
    Bill Clupper #618
    • Phil P.
      • April 1, 2006
      • 409
      sounds like a caddy buick olds ponch lighter--love those old cars
      • Wayne M.
        • March 1, 1980
        • 6414
        NOS 63 Casco 12V (showing porcelain)
        As Bill said. I think they were used in '63 and '64 as well (if not, others will let us know).
        I retracted the spring loaded shroud to expose the porcelain.
        • Gerard F.
          • June 30, 2004
          • 3806
          Re: NOS 63 Casco 12V (showing porcelain)
          Thanks, Wayne
          A picture is worth a thousand words.
          The one's that I have, have a copper ring but not touching the sides of the housing.
          Jerry Fuccillo
          Jerry Fuccillo
          • Gerard F.
            • June 30, 2004
            • 3806
            How long is the housing?
            Wayne
            Is it the 1" one or about 1/8" shorter.
            Jerry Fuccillo
            Jerry Fuccillo
            • Wayne M.
              • March 1, 1980
              • 6414
              0.875" by dial caliper
              or 7/8", with the element retracted in the shroud. the 3 bend tabs on the knob end add about another 6 thou if included in the measurement.
              Regards, Wayne
