67 300HP K19 (AIR) engine pics - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5138
    Does anyone have pics of an original (or correctly restored) engine for a 67 300 HP AIR-equipped car? This one was taken apart in 1981--most of the stuff is there, but clips/hoses etc. are not labeled--all the bolts, fortunately, are in little plastic bags with wire-on tags.
    This car has no AC, no power steering or brakes, by the way.
    Also--there is a threaded hole in the top of the intake manifold for a vacuum fitting (power brake, etc.)--what type configuration should be used for a non-power car? Is that used for the AIR? If not, and it is plugged, is it a standard type of square-headed pipe plug?
    Thanks for any help--if you have any pictures, please email them to me at
    mikeerns@wi.rr.com.
    Re: 67 300HP K19 (AIR) engine pics
    Mike -
    You have mail
