C2 headlamp gear reassemble - NCRS Discussion Boards
  • Gus Gates
    My C2 headlamps stop working and I found out the headlamp motor drive gear was worn. The other gear appears fine. There is a nylon washer with two slots in it. Does it matter how this is reassembled? Thanks
  • William C.
    • May 31, 1975
    • 6037
    Re: C2 headlamp gear reassemble
    If it has not already been done on your assembly, the driven gear only travels 180 degrees during activation, so reversing it to use the unused gear teeth is a perfectly acceptable practice to renew the function.
    Bill Clupper #618
    • Albert P.
      • April 1, 2006
      • 205
      The nylon washer goes on the gear side that faces the motor assembly.
