Camshaft identification - NCRS Discussion Boards
  • John Pelkofer Jr
    Hello, I am trying to help a friend identify a camshaft installed in a rebuilt
    1966 427/425hp engine he recently purchased. Two numbers appear on the invoice.
    The first number is 3959180 and the second is 11454R. Thank you in advance for
    any and all help. Thanks, John
  • William C.
    • May 31, 1975
    • 6037
    Re: Camshaft identification
    560/600 lift cam released for ZL-1, NOT a street cam in any way. Also referred to as second design L-88 cam.
    Bill Clupper #618
      • 43221
      John-----
      GM #3959180 is the part number for the 1969 Corvette ZL-1 camshaft. I don't know what the "11454R" refers to. It might be a Federal-Mogul part number.
      • John Pelkofer Jr
        Thank you Bill and Joe. I am going to recommend a camshaft change before
        installation. This engine is going into a power brake car and I know it
        will not produce enough vacuum. Thank you again, John
        • Clem Z.
          • January 1, 2006
          • 9427
          better check the valve spring also
          because they could not be compatible with the next cam you plan to use
