I was getting swings in the charge rate to the battery and so I have just replaced my voltage regulator. The ammeter is now reading very wildly... I believe the connector was installed correctly on the base of the regulator. The car shows a negative draw when the lights are turned on and moves to the right of the 0 center line when the engine speed increases.
The issue is the readings are very extreme. For example, at idle with the headlights on, the ammeter registers a -20 reading....when the idle increases, the ammeter then shows a +20 reading that gradually works back to the 0 line.
At highway speed, the ammeter is showing a slightly negative (-1) reading, just to the left of the 0 line. At normal idle with little draw on the battery, the ammeter is moving all over the place.
I checked the charging rate at the battery. When the engine is just started the charge is at 14-14.5 at high idle. As the engine reaches normal operating temp, the charging rate drops to below 11-11.5. I shut the car down and retested with pretty much the same result.
The alternator was replaced last year (less than 1500 miles ago) with a correct, dated unit.
Can the alternator need some work?
Should I replace the regulator?
Can the ammeter be adjusted?
New to many technical issues with my 67, so I may not have done other tests or know how to do other tests to confirm which part is toast.
Appreciate any guidance. Thanks.
