66 AC Battery Cable Ground - NCRS Discussion Boards
  • Mark J.
    • March 1, 1996
    • 254
    Where does the negative battery cable bolt to the engine on a 66 327 with C60? I am adding AC to my car and do not have a reference point.
    Thanks in advance.
    MRJ
  • Dennis B.
    • May 31, 2004
    • 175
    Re: 66 AC Battery Cable Ground
    Mark,
    First off the batteries are located on the driver side for 66 AC cars. My negative cable goes to the block via a very short cable routing under the steering column and clutch rod assembly.
    • Mark J.
      • March 1, 1996
      • 254
      Is your cable connected to the bellhousing bolt located directly behind the oil filter?
      • Dennis B.
        • May 31, 2004
        • 175
        That's correct.
