1961 fuse problem - NCRS Discussion Boards
1961 fuse problem
+ More Options
Posts
  • Ron Gaal
    1961 fuse problem
    I am a brutal mechanic I thought I bought this car DONE!
    I bought a cicuit tester, is there a certain spot to put the ground clip?
    Non of the terminals show any power and I no some work(parking break lite)any help would be greatly appreciated!! Ron
    • May 31, 1974
    • 8401
    Re: 1961 fuse problem
    if you have a long enough lead, ground it on the neg battery post. otherwise, ground it on the frame or engine. all surfaces need to be oil/grease free. good luck, mike
    • Ron Gaal
      I will try THANKS *NM*
