tires and jets - NCRS Discussion Boards
tires and jets
  • corky
    tires and jets
    I have a 74' and would like to know if anyone can tell me the manufacturer or brand name of the tires that came on it when new, i.e. Goodyear, Firestone etc.? Also, can anyone tell me the original jet size and correct mettering rods for the carb. The vin is 1237J4S400215 and it is a L48 equiped car. Thank you, Corky.
    • 43240
    Re: tires and jets
    For 1974, Corvettes were supplied with GR70-15 radial tires. Many Corvettes during 1974 were equipped with the "Firestone Steel Radial 500" tire, although other tire brands may also have been used.
    As far as carburetion details go, your car was originally equipped with a Rochester Model 4MV Quadrajet Carburetor, GM #7044206 if your car is an automatic trans or #7044207 if manual trans. Either carb used the following jets and metering rods:
    primary jets-------GM #7031975---number 75---.075"orifice size prim. met. rods----GM #7034836---number 36B sec. met. rods-----GM #7045779---identifier "CH"---.1353"/.1060"/.0570"
    • Paul B.
      • April 30, 1995
      • 482
      Re: tires and jets
      Corky, as Joe L. mentioned, the Firestone 500 was one brand installed on '73 thru '77 Corvettes. The other known brand was the Goodyear GR70-15 "STEELGARD" radial tire. Both these brands came three ways, standard blackwall or optional white stripe or white letter. The Firestone 500s were recalled due to the tire separating internally. A friend of mine was driving his Corvette with these recall tires last summer(he did'nt know anything about the recall) and a left rear tire literally came apart at about 45mph and ended up doing severe damage to the driver's side dogleg behind the door. Paul Borowski Massillon,Ohio
      • Tom Freeman
        Joe, a follow up
        Joe, what would the carb jets and rods be for a '73 L82 auto?
          • 43240
          Re: Joe, a follow up
          Tom-- I'll need to research that one; I'll post this evening.
            • 43240
            1973 Corvettes with L-82 and automatic transmission were originally equipped with Rochester Quadrajet Model 4MV carburetor number 7043212. This carburetor had the following jets and metering rods:
            primary jets----GM # 7031974---number 74----orifice size .074"
            prim.met.rods---GM # 7034844---code 44B-----double taper type rod
            sec. met, rods--GM # 7046010----triple taper type rod.
            • Tom Freeman
              Joe, Thank You....n/m
              n/m
