1965 Roadster -
I received the Kelsey Hayes 15 x 5.5" rims back from being media blasted and epoxy coated and will now be painting the back and inside with satin rustoleum. Will paint the face with gloss rustoleum.
Went to Carlisle this past weekend and purchased the hubcaps.
The Judging manual says the valve stems are 1 3/8" - is there a need to look for other than current production valve stems. The "nippled" valve caps are continuously offered on Ebay for about $10-$11 - and I assume they will be correct for judging.
Regarding the wheel weights - the judging manual says they are to be mounted on the inside (only) ? Should I look for original weights - escecially since I don't know what different weights i will need for each wheel - or simply have current production weights used when having the rims/tires balanced ?
I intend to move the Firestone bias ply goldlines to the steel rims for judging - and will be purchasing tires for the knockoffs that are on the car now to use as "drivers". Previous posts have me leaning to the Diamondbacks as opposed to the Coopers.
Am I off track anywhere ?
thanks in advance.
Noel Kendall
thanks in advance.
Noel Kendall
