L 88 J56 brakes and front hub spindle - NCRS Discussion Boards
  • deep south auto
    do the brake pads have a steel backing that is angled over the exposed portion of the pad? and, is this steel backing plate painted red?
    is the upper and lower portion of the spindle upright painted engine orange with the center portion left bare metal?
  • Sal C.
    • December 1, 1984
    • 430
    Re: L 88 J56 brakes and front hub spindle
    Original J56 pads have steel backing plate that angles over the edge of the caliper. The lettering on the top of the pad should be red but I have never seen the backing plate that color.
    • Dan M.
      • November 1, 2000
      • 48
      The set that I have does have some type of red coating to it but it looks more like a protective coating to the steel part of the pad not actually paint. I have pictures (of pads, calibers and brackets) and would be happy to send if you will provide me your address. FYI the lettering on the pads is white and repeats " FXMIEE FXMIEE FXMIEE" email your.
      Dan
      NCRS # 35068
      Dan Morlang
      • Mark #28455
        mine has some burgundy stuff
        covering the part of the Inconel backing plate that bends over the caliper.
        Mark
        • Dan M.
          • November 1, 2000
          • 48
          Re: mine has some burgundy stuff
          Mark,
          Actually Burgundy is closer to my color as well. My eyes just aren't what they use to be.
          Dan
          Dan Morlang
          • Wayne M.
            • March 1, 1980
            • 6414
            Pic of J56 front pads
            The box has part # 5468882 and the red/orange stamping reads "DELCO" (903FF) 5468883 (repeats). You can see how the burgundy "spray" was intended to be applied to the surface of the pad contacting the backing plate.
            • Sal C.
              • December 1, 1984
              • 430
              Re: Pic of J56 front pads
              Thats the way they looked when they left ST. Louis...Red letters.
