327/350 HP considered Spec High Perf? - NCRS Discussion Boards
  • Phil B.
    • Today
    All - looking to order a few parts for a friends 1966 327 350 HP car he just got last night. In looking at Paragon's catalog it lists for 327 and 327 Special High Performance. Is the 350 HP considered Special High Performance? Thanks
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 327/350 HP considered Spec High Perf?
    That's correct Eric. It was one of only two different 327's for the 66 model year. The 300 HP was base and the 350 was Sp.H/per.
    • Gary B.
      • February 1, 1997
      • 7023
      327/350 HP considered Spec High Perf? Yes, but
      Eric,
      the '65-'67, L79 327/350 HP engines used hydraulic lifters, not solid lifters.
      Gary
        Re: 327/350 HP considered Spec High Perf? Yes, but
        Any small-block midyear with an aluminum intake manifold was categorized as an "SHP" engine by GM.
        • Phil B.
          • Today
          Thanks - I can now safely order the correct parts.
          • Wayne M.
            • March 1, 1980
            • 6414
            Where there was a need to differentiate ...
            the parts catalogs added (w/Hyd. lifters) to the Sp. H/Per. designation [check Gr. 0.519, Camshaft for example]
