C3 oil pressure - NCRS Discussion Boards
C3 oil pressure
  • Joseph K.
    • March 1, 1980
    • 168
    C3 oil pressure
    My wifes 75 coupe has a very erratic oil pressure . The needle on the face lookeed as if it is being hit with Tazer. What if anything can be done to remedy this situation. I always check the oil before driving and find it a he right level.............Any ideas?...............Joe
  • Lawrence S.
    • April 1, 1993
    • 801
    Re: C3 oil pressure
    Have you check the connection at the oil sending unit?
    • Bob R.
      • June 30, 2002
      • 1595
      Re: C3 oil pressure
      I would make sure the gage is reading correctly. If the problem is actually the oil pressure bouncing around you may have some engine work ahead of you.
