'60 ignition switch/wire connectors - NCRS Discussion Boards
  • Matt F.
    • June 30, 2002
    • 79
    The other day I accidentally bumped the ignition switch, from behind, while the car was running at idle - it hesitated, then kept on OK. The next time I drove it, it hesitated while I was driving, and I believe I've got some loose wires at the switch. I see some copper showing, and I'd like to 're-do' the connection of the wires to their terminals, but I can't figure out how to get the terminals out of those little hard plastic covers. How do ya get them out?
    -Matt
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '60 ignition switch/wire connectors
    First disconnect the battery , I use a small flat screw driver and under the plastic I pry them up
