C1: Stupid question of the day - NCRS Discussion Boards
  • Dave F.
    • June 30, 2004
    • 443
    The front emblem bowl (or whatever you call it) on my 1959 is dirty inside and I'd like to clean it out. With the hood up I can reach the assembly, but those quick nuts are harder than hell to get off. I'm afaid I'm gonna slice my fingers if I try any harder. Any suggestions for getting these off?
    Thanks.
    -Dave
  • Anthony F.
    • December 1, 1985
    • 191
    Re: C1: Stupid question of the day
    Dave,
    Corvette Central and other Corvette parts suppliers sell a tool made for that nut.
    However if you have some talent you can cut a socket to fit the flanges.
    • Dave F.
      • June 30, 2004
      • 443
      Thanks for the tip Tony. You may be assuming too much, so I'll get on the phone to Corvette Central.
      -Dave
      • Christopher R.
        • March 31, 1975
        • 1599
        Bet if you put a cloth over the nut, it'd protect your fingers enough that you could generate enough torque to unscrew them. Otherwise, the tool will work. There's a tendency with the tool to overtighten. Resist that urge.
        • Dave F.
          • June 30, 2004
          • 443
          I tried that, but it didn't work. And yes, if I get the tool I'd only use it to remove the nut, not put it back on. Thanks for the tip.
          -Dave
          • Kent D.
            • February 1, 1992
            • 100
            Remove the grill, then you will have more room to work. Use an adjustable wrench.
