C2 67 Jack finish - NCRS Discussion Boards
C2 67 Jack finish
  • Stephen L.
    • May 31, 1984
    • 3158
    C2 67 Jack finish
    I'm refurbishing my jack. Anybody know if the jack was assembled with the lead screw in it before it was painted... or are the screw and washers natural?
    Semi-gloss black the color of choice?
  • Gary B.
    • February 1, 1997
    • 7023
    C2 67 Jack finish
    Steve,
    How you looked at the posting from last week or so entitled "C2 - '67 (late) Jack and Wrench"?
    Gary
    • Stephen L.
      • May 31, 1984
      • 3158
      Re: C2 67 Jack finish
      Yes. Thats what got me started on refurbishing mine. In the photo it appears that part of the screw is painted while the ends are not. I'm just trying to verify if thats correct.
      • Barbara S.
        • April 30, 1981
        • 599
        The painted portion of the 67 jack is gloss black-not semi gloss black.
        Tony
        • Gerard F.
          • June 30, 2004
          • 3806
          Steve,
          The picture in this post is an untouched original 67 Jack (except for the bolt in the wrench which replaced the rivet). This jack was rolling around my jack compartment for some 37 years before I refinished it.
          A portion of the screw on the nut end was painted as it shows in the picture. The washers were natural zinc plated. In refinishing it, I was careful to replicate the original painting by screwing the jack up tight, and masking the outboard screw part and the washers. I then spray painted it with Rustoleum Gloss Black (rattle can) in a couple of light coats. (Hung it on a wire from the garage rafters under a heat lamp.)
          Jerry Fuccillo
          #42179
          Jerry Fuccillo
          • Barbara S.
            • April 30, 1981
            • 599
            Jerry. Does your jack have a date on it?
            Tony
            • Stephen L.
              • May 31, 1984
              • 3158
              Re: C2 67 Jack finishTHANKS JERRY! *NM*
              • Gerard F.
                • June 30, 2004
                • 3806
                Tony,
                Other then the 7E on the scissors leg, I don't remember seeing any other numbers on it. I'll look again today, as I'm starting the convertible top frame restoration. If 7E means May 67, that would seem to fit my June car.
                Jerry
                Jerry Fuccillo
                • Barbara S.
                  • April 30, 1981
                  • 599
                  Jerry. Same here. I've got the same 7 E on mine.
                  Tony
