I am preparing for the body lift on my 54' this weekend but am having a problem with the disconnection of the emergency cable at the firewall. Perhaps your advise would prevent my breaking the cable or housing.
I removed the spring clip on the cable at the firewall but cannot pull the cable or housing out of the socket where the large nut is. I can turn the cable housing in the socket about a 1/4 turn but no more. Pulling the housing does not help at all and it appears the nut is locked tight on the treaded end of the brake handle shaft at the firewall. Am I missing something here or should I try and apply heat to the nut at the firewall (not me) and try to loosen it? Any other thoughts even if it is disconnecting underneith the car.
John Lanning
John Lanning
