'72 LT-1 AIR Pump Date Code - NCRS Discussion Boards
  • Steve B.
    • July 31, 2002
    • 52
    I'm confused on the date code of the AIR pump that came with my '72 LT-1. The stamping on the boss at the bottom of the pump has 066319 on it. There may be a "K" or "X" in front of the 0, but I can't tell for sure. It may even be a scratch on the boss because that stamp doesn't match the 066319 at all. What date is this?
    Thanks in advance.
    1994 ZR1 Green / Beige
    2009 Cyber Gray / Red Coupe
  • Dick W.
    • 10483
    Re: '72 LT-1 AIR Pump Date Code
    "If there is a first letter, it is for the assembly line. The next three numbers are Julian date; the fourth number is the last digit of the year; fifth number is the shift, and the last letter shows the model of the pump." From the 70-72 JG & TIM. 066319 works out to be the 66th day of 1973, 1st shift and ???? Should be a letter, not a numeral
    Dick Whittington
      • 15601
      That last letter is usually an S for Corvette applications.
