1967 Tank Sticker - NCRS Discussion Boards
1967 Tank Sticker
  • Peter K.
    • January 1, 1999
    • 117
    1967 Tank Sticker
    I just droped the tank off of my project 1967 435 hp car and was extremely exicited to find the original sticker, most of the important info is still legible but barely...I want to get a sticker made to duplicate mine (so I can keep the original in my safe)the inspectors number seems to be either 342 or 842 but can't tell for sure. My car is number 2931 does anybody have a car near to my Vin that can tell me where my inspectors number should be?
  • Steve Wallach
    Re: 1967 Tank Sticker
    try scannig the sticker, the number may be more visible. Also, the number should be chalked on the body tub, in front of the Fuel Tank (the back side of the jack storage compartment on the outside of the car), as well as the engine compartment side of the passenger floor board. The number should be the same in all these locations and on the sticker.
    Hope that helps,
    Steve
    • Kevin M.
      • November 1, 2000
      • 1271
      And on each door.
      Kevin
      • William L.
        • December 1, 1988
        • 944
        I dont think that the hand written pencil # on the tank sticker is always the same as the hand written chalk # on the body parts.
        Bill
        Bill Lacy
        1998 Indy Pacecar
        • Brian M.
          • February 1, 1997
          • 1839
          I wouldn't buy a repro, I'd take a picture of the original.
          • Stephen L.
            • May 31, 1984
            • 3158
            The penciled number on the tank sticker is typically 1 or 2 digits before the last 3 numbers of the VIN#. If the last 3 numbers of the VIN are over 500 then the penciled number will be VIN# - 500 less 1 or 2 digits.
            Example VIN = xxx456 then penciled number = 456-1=455
            VIN = xxx789 then penciled number = 789-1-500=288
            The JOB number on the body panels and doors is NOT the same as the penciled number on the tank sticker.
            • Stephen L.
              • May 31, 1984
              • 3158
              It typically never is the same as the number on the tank sticker was near the VIN#; either right on or within a digit or 2. Of course the "500 repeat" rule is also included in that number sequence.....
              • Ron Hambrecht
                If the last 3 VIN#s are over 500, the penciled number could be minus 1, 2, or 3.
                My VIN is xxxxxxxxxx574, and my tank sticker chasis line number is 71
                574 -3 -500 = 71
                • Stephen L.
                  • May 31, 1984
                  • 3158
                  Sometimes they are even the same.....no subtractions
