Re: C-1 Tires - NCRS Discussion Boards
Re: C-1 Tires
    Re: C-1 Tires
    205/75-15 radials will work fine. If you experience issues with the wheel covers rotating on the wheels after mounting the radials, have steel valve stems installed.
  • Dwight Bedsole
    Re: C-1 Tires
    John,
    What a beauty. My '57 never looked that good, hopefully my '58 will come close.
    One more question - Do you really get better handling and ride with radials ?
    Dwight
    • Roy B.
      • February 1, 1975
      • 7044
      Re: C-1 Tires
      Qwight
      Mine are 215x75Rx15 having 5in wide wire wheels, They look great ride great fit great and steering is great , I've driven many C1's and many ride and steer lousy , I think they are assembled wrong , steering box adjusted wrong or alignment is bad. But our 55 is a pleasure to drive and is better using Radial tires. We have put over 100,000 mile on the 55 after I restored it 26 years a go and it has the original engine.
      • Roy B.
        • February 1, 1975
        • 7044
        Re: C-1 Tires
        I also added a booster that will put you through the windshield for $150.00 using the original brakes and drums.
          Re: C-1 Tires
          You won't believe the difference between bias-plys and radials - it will drive like a different car.
