Clutch Pedal '57 - NCRS Discussion Boards
Clutch Pedal '57
  • Ron B.
    • 58
    Clutch Pedal '57
    When the clutch pedal on my 57 goes beyond a certain point, it "sticks" to the floor and must be released by pulling it up with my foot. I've checked to see that everything is attached correctly. What have I done wrong?
  • David K.
    • February 1, 1976
    • 592
    Re: Clutch Pedal '57
    Ron, your over center spring is out of adjustment or springs are weak in the pressure plate.If you can borrow or buy the Corvette Service Guide around here we called the ST-12. It is a wealth of adjustment info.
    • dale pearman
      Brake pedal do the same?
