C1 Signal Light Flasher - NCRS Discussion Boards
  • Jim Sloan
    I have a 1960 and was wondering what is the correct number and shape of the signal light flasher that plugs into the underdash fuse block. I am presently using a round Tridon #552. I cannot seem to find this information anywhere.
    Thanks in advance.
  • Gene B.
    • May 31, 1990
    • 144
    Re: C1 Signal Light Flasher
    Jim,
    I believe the flasher is a Signal Stat with a flat rectangular shape, with I think the number is ZN-132. It is about 3/8" thick and 3/4 high and 1 3/8 wide. Doesn't the 58-60 JG indicate the correct flasher?
    I can double check on my 58. They are the same for 58-60. I think 61 and 62 changed to a round can type, with the three lamp configuration. I used to know these numbers off the top of my head, but I'm starting get like Mike.
    Gene
    • William C.
      • May 31, 1975
      • 6037
      ZN-232 is one of the square numbered parts, there were also two others used, including the signal stat 145, and one other I can't ID at the moment.
      Bill Clupper #618
