Getting parts ready for winter project. Relative to the Ignition Shielding for a 1964 FI;
1 The ignition shield support brackets, 3819757, 8, & 9, what is the finish on these and are they painted org? Want to use original ones with correct markings.
2 The brackets which the ign wires run through and also hold the shielding, are these painted black and what flavor (gloss, semi,flat, ..)?
3 Have two styles of the lower rear L.H. bracket (those described above in 2)
One is straight while other has a section which thins then goes back to same
dimention as started. (can send picture, but no idea how to post).
Paragon shows two of these, one for 56-69 the straight one while the other is
for 65-67 but with a section take out entirely while mine only has a small
section removed (could this be a 63??)
