When removing the speedometer cable at the 4 speed transmission, in which direction should I manually spin the cable to make the speed indicator pointer move in the speedometer; clockwise or counterclockwise?
I did not want to use trial and error for fear I may damage the spring in the speedometer if I turn it in the wrong direction.
Thank you,
Kurt
Thank you,
Kurt
