Quadrajet date coding - NCRS Discussion Boards
  • Bruce L.
    • December 1, 1998
    • 9
    I have been researching a correct replacement Quadrajet for my 1972 small block/auto/AC car.
    I know the "part number" should be 7042202.
    My question concerns date code schemes for Quadrajets. All of my "web research" so far
    suggests that these carburetors were date coded using four digits, like:
    DDDY --> DDD = sequential year day, Y = last digit of the year
    However, I have now seen several quadrajets for sale on the web with no four
    digit code, but instead some combination of four letters and numbers.
    I typically see a pair of letters (which MIGHT be a code for the factory
    where the carburetor was made....or installed) plus a second pair consisting
    of a single letter and a single digit. It seems like most people interpret a
    single letter plus a single digit as an alternate form of date coding, like:
    MY --> M = letter code for month, Y = last digit of year
    Was that scheme for date coding ever used for these carburetors?
    If so, does A=January, etc. or was the letter A referenced to a different
    starting month (August, for example)?
    Thanks for any help.
    Bruce
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Quadrajet date coding
    Bruce
    You have the date code correct in both cases. The first way you stated is the rochester code jullian date then year. Carter also made rochester's and their code is letter year.
    Lyle
    Lyle
    • Bruce L.
      • December 1, 1998
      • 9
      Thanks Lyle. For Carter date codes, does the letter A stand for January?
      Bruce
      • H S.
        • August 31, 1994
        • 36
        Lyle
        I have had an old Q Jet laying around for some time, it also is stamped 7042202, D2, circle with C inside, DJ. Is D2 april of 72, circle with C Carter built and DJ a broadcast code??
        H P Shuttleworth
        • Harmon C.
          • August 31, 1994
          • 3228
          Yes A is January, B Feburary------------
          Lyle
            • 15606
            Yes, the DJ is a broadcast code.
