69 427 rad/shroud hardware - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Where would I be able to find the correct hardware for the two upper brackets that bolt to the radiator support and are used as the upper cradle for the radiator? There should be two bolts and two washers per bracket.
    Also, where could one find the correct machine screws/bolts for the lower rad shroud extension? There should be three of these but not sure if there should be washers or not.
    I've search quite a few vendors with no luck on these so any help is appreciated.
  • David H.
    • December 1, 1996
    • 241
    Re: 69 427 rad/shroud hardware
    Old busted up fan shrouds are a good place to get what you need if the Dr. does'nt have them. The extension bolts will be machine screws and a metal insert type nut goes in a drilled hole in the shroud or extension to recieve the screw.
