getting sparking action on negative battery wire - NCRS Discussion Boards
  • Gary #41345
    When I go to start my 66 coupe I get some sparking action out of the negative battery terminal??? The battery sometimes will not turn over now and I have to jiggle the terminal connectors...although they do not appear to be loose.
    Bad cables? Bad connection under car? The negative wire is very tight as it extends below the spark plug shielding..is this typical? I purchased new repo wires from ecklers just in case but haven't installed them yet...ideas?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: getting sparking action on negative battery wi
    Put the new cables in
    • Robert S.
      • July 31, 2004
      • 377
      And clean the battery posts. *NM*
      Bob
      • Gary #41345
        Thanks Roy, was the cable as the new one has yet to produce the problem the old set did.
