Electrical - the more I look the more I find!! - NCRS Discussion Boards
  • Nick Mesich
    My Temperature gauge on my 66 vert L79 327/350hp was not working so replaced the gauge twice, Sender once, then started looking at my wiring harness.
    Found a poorly repaired area of the Water Temp Sender wire just as it goes into the wiring harness from the engine. Bubba used one of those crimp ons to connect a new wire to the remaining original and over crimped it. Repaired it with a proper solder job and shrink tube, tried the gauge again and still no luck.
    Continued to trace the wiring. Pulled the bulk head connectors on the fire wall and noticed some green build up and three of the pins pushed in. Two on the firewall side and one on the plug on the engine harness. Pulled them back out to their original position, cleaned everthing up with Electrical contact cleaner, brass brush, then a light film of Dialectric grease. Re attached everything then continued looking at the engine side wiring harness.
    Damn! if the Thick red alternator wire had not melted it's plastic sheathing and the black electrical tape for approximately 8 inches from just behind the bulk head connector where the wires intersect back 8" towards the alternator. You could clearly see bare wires for almost the whole 8". Doesn't look fresh, looks like it's been like that for a long time. (Can you say fire hazard!!!)
    Looks like an engine harness replacment job. Really wasn't planning anymore projects till fall. But this just can't be left alone.
    Who carries the best harness at the best price and do any of the vendors offer any discounts for being NCRS members?
    Any suggestions for this task? Anything else I will need or to look for?
    Nick
    Always something with these old cars.
    There goes another weekend.
  • Rick S.
    • January 1, 2003
    • 1203
    Re: Electrical - the more I look the more I find!!
    I put in an Letric Limited engine harness and have been told it is a correct replacement. I don't think they offer a NCRS discount though as I bought mine over 2 yrs ago and can't say for sure if a discount was offered.
    • Michael M.
      • February 15, 2007
      • 455
      I bought a Lectric Limited rear witing harness for my '68 and it appeared to be spot on both with the connectors and wire colors, etc.
      • Harry Sadlock
        Nick, Call Paragon and ask them who supplies their harnesses. If you like the supplier give Paragon your NCRS number and get a 10% discount.
        Harry
        • Robert E.
          • April 1, 2004
          • 398
          Harry,
          I was recently informed by Paragon, to receive a discount, an initial purchase of $500 is required.
          Robert
          41801
          • Harry Sadlock
            Must be a new policy. Let's pressure them at Carlisle and find out why!
            Harry
            • Nick Mesich
              Re: Electrical - Temporary Fix?
              Thank you Gentlemen for all the responses and information.
              What do you think of using Liquid electrical tape as a very short term fix to seal that red alterator wire back up, check that part of the harness for any other bare wires and seal them up also and then wrap regular electrical tape around that part of the wiring harness to finish.
              I would guess I had been driving the car with the bare wires exposed like that for over a year and in the mean time a temp repair as I mentioned above should hold until I can get my new harness ordered and in.
              Or do you think I am pushing it and playing with FIRE(literally).
              There is a show this weekend that I would like to attend.
              Nick
              • Mike McKown
                If it was mine, and it isn't
                I'd get a piece of rubber hose. Split it and slip it over the bare section and wrap electrical tape around it and go to the show. But, it's not my car. Proceed at your own risk. Small as it may be.
