66 carb spacer - NCRS Discussion Boards
66 carb spacer
  • Dean # 33,398
    66 carb spacer
    Does a 327/350 stock carb have a spacer under it? thanks Dean
  • Bill Clupper
    Re: 66 carb spacer
    Not a spacer per say, but I believe a stainless steel baffle is used under the carb, same as 300 horse if I'm reading the assy manual correctly.
      • 43221
      Re: 66 carb spacer
      Dean-----
      No, there should be no spacer. There should only be a gasket between the manifold flange and carburetor on a 1966 L-79.
      • dale pearman
        Re: 66 carb spacer
        Whats an assy manual?
        Dale.
        • Jerry Clark
          Re: 66 carb spacer
          I have half an assy manual
          jer
          • Ray Morrison
            Re: 66 carb spacer
            Dean, I would not expect to see a spacer under the carb - just the standard gasket.
