another oil leak question - NCRS Discussion Boards
  • jim cear
    After researching the archieves and checking the usual , valve covers, dist., oil pressure line,fel pro one piece gasket, etc. I have a leak that drips from the bottom of the bellhousing, not much, just a few drops after a couple of days. Thats the the part that I thought may help someone point me in the right direction. This leak won't show up until the car has sat for a day or more.Is that any help? Any ideas? (327/340hp).
  • Chuck R.
    • April 30, 1999
    • 1434
    Re: another oil leak question
    Hi Jim,
    If your guaranteed that the items listed above in your post are bone dry, then I'd look to rule out the following as well.
    Rear main seal
    Oil pan gasketing especially the rear pan to bearing cap seal
    Oil gallery plugs
    Good luck on your search,
    Chuck
    • Rob Dame
      Could be coming out the trans input shaft. If that is all the leaks you have you ought to consider yourself lucky. Rob
      • Joe C.
        • August 31, 1999
        • 4598
        Jim,
        How long has it been leaking? Has the engine been taken apart recently?
        It sounds like the rear main seal to me, most likely. There are oil gallery plugs in the back of the block (forward of the flywheel), but is not likely for them to leak.
        If you have not already done so, thoroughly wash the rear half of the engine and make sure that the leak is not from the top.
        Smell the fluid to determine whether it's not gear oil. Another possibility could be a leak in the trans idler shaft where it's presed thru the front of the case. This is a common problem with Muncie gearboxes. Less likely could be a leaky trans front seal.
        Good luck.
        Joe
        • Barry Chappell
          I had a very similar leak. Appeared to be the rear main seal, however, after replacing the seal I still had the leak.
          Eventually I found the leak. It was coming from the rear seal on the intake manifold.
          Barry
          • Clem Z.
            • January 1, 2006
            • 9427
            if the rear main bearing cap was replaced
            without proper sealing to the block all the changing of the rear crank seal will not help as the oil is coming out between the rear cap and block surface
            • Jack W.
              • August 31, 2000
              • 358
              same as Barry
              for me what appeared to be a main seal leak turned out to be leak from a rear corner of the intake manifold where it mates with the block (I hestitte to us the term "gasket" because it is a seal created with permatex, unless you actually use the little strip of gasket supplied by the maker.
              This on a 65 L76, aluminum intake - not an unusual leak from what I have read and been told.
              • Mike R.
                • May 31, 2002
                • 119
                Mike Robb
                  • 15669
                  Rear main seals get blamed a lot, but they are often not the culprit. If the rear main seal leaks there should be a film of oil on the front of the flywheel, and you can inspect by removing the sheet metal inspection cover on the front/bottom of the bell housing. If the front of the flywheel is dry, the rear main is probably not the bad guy.
                  Any minor leak or seepage can end up at the back of the engine. Oil from front leaks can migrate along the pan rail and not drip until they reach the lowest point of the engine at the very rear.
                  Oil leaks can be real tricky to find and the first "obvious" choice is often not the culprit.
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    Leaks!! my 55 is like a Harley , they know where you park, I drive it to much to worry about a little leak and never worry about a rusted frame.
