T10 question - NCRS Discussion Boards
T10 question
  • Terry K.
    • July 31, 1975
    • 82
    T10 question
  • Mike E.
    • February 28, 1975
    • 5139
    Re: T10 question
    Terry--
    Assembly stampings are not on the top. They're on the side, on a boss, right in front of the side cover. That'll quickly tell you what you need to know. The tailshaft housing info you gave is inconsequential--they all have that info on them.
    • Terry K.
      • July 31, 1975
      • 82
      Re: T10 question
      Mike:
      Thanks! I'll check a little closer! It is pretty oily and a mess under there - 35 years of neglect!
      I am still curious about the "R - 2" though??? It is obviouly not a normal date code. Since it appears to be an insert, they must have been documenting something.
        Re: T10 question
        Terry -
        The assembly date code is stamped on a machined surface on the driver's side, just rearward of the rear upper corner of the side cover. The "R 2" is probably a mold number.
          • 43236
          Re: T10 question
          Terry-----
          Keep in mind, too, that just because it has an aluminum main case and aluminum extension housing does not necessarily mean that it came out of a 1962 Corvette. The aluminum main case was used for 1961-62 Corvettes as well as 1962 Chevrolet passenger cars with 409. So, it could have been originally fitted to any of these applications. The VIN derivative stamping will confirm which. However, it's really only an academic point. Regardless of where it originally resided, the transmission would be the same.
            • 43236
            Addendum
            I should also have mentioned that while the Corvette and passenger car transmissions for the years and applications mentioned would be the same, the transmission could be either a close or wide ratio.
            • Verne Frantz
              Re: Addendum
              Terry has not given us enough to go on. Let's start with the assembly date stamping on the main case, just behind the side cover. We don't even know if it's a T10-1C case. Both the T10-1C main case and the T10-D1 main cases used the T10-7D extension housings. ALL '62 Passenger cars with 4-spd had the T10-1C aluminum case transmission - 250hp, 300hp, 380hp & 409hp. If a '62 dated iron case T10 is located, it is probably from a Buick, Olds, Pontiac or Studebaker, or it's a service replacement for an earlier Chevy application.
              The only '61 Passenger cars with the T10-1C case were cars produced with one of the 142 409s, beginning in January '61, which I believe was before the Corvette changed from the 1B case to the 1C case. VERY late in the '62 model year, a few T10D-1 cases appeared in Passenger cars and continued until mid Feb. of '63 before the change to the Muncie.
              The '61 409 T10 was a 2.20 1st ratio. For '62, the T10s were 2.54 ratio for both small blocks and 2.20 ratio for both versions of the 409 (with the 2.54 wide box available with the 3.08 rear).
              But, as Joe said, each transmission "type" was identical between Corvette and Passenger except for ratio, depending on engine and rear axle options. (Except '63 409 T10s used a large diameter cast iron front bearing retainer rather than the small aluminum one for the 421 bellhousing.)
              Verne
                • 43236
                Re: Addendum
                Verne-----
                I believe that the T-10D main case was the 63-only case set up for the smaller diameter bearing retainer. That would not work on any C1 bellhousing. So, presuming that the 1960 in question still has a C1 style bellhousing, I don't think that a T-10 with a T-10D case could be installed.
                • Verne Frantz
                  Re: Addendum
                  I agree Joe. Assumming he still has the correct bellhousing, it would have to be the T10-1C case (unless he has a '63 409 transmission with the large front retainer)
                  Verne
                  • Terry K.
                    • July 31, 1975
                    • 82
                    • Verne Frantz
                      Re: T10 question
                      Hi Terry,
                      I believe you've decoded everything correctly. It is a "'63" transmission. I'm sure the Corvette assembly line was much more judicious about stamping the VIN derivitive on the transmissions than a lot of the Passemger car plants, so if no VIN derivitive can be found, it is probably from a passenger car, or possibly it was a service replacement transmission.
                      You didn't mention which bellhousing is in your car. But if you've enjoyed the car for 36 years with that transmission without a problem, I'd have to guess that the trans has the correct size bearing retainer for the bellhousing. I'm not sure if you can get close enough to remove the clutch fork boot and peer in there.....
                      Verne
