This question will hopefully be best answered by Clem, Duke, or any of our more renowned engine/carburation gurus.
My 1965 327/365 runs fine, and pulls strongly at the top end. There is no black smoke, or any smoke for that matter. There is no lean misfire or surging. The engine is built to original specs EXCEPT that the heads are massaged (pocket ported, polished, gasket matched, cc'd, valves reprofiled, further unshrouded chamber). The engine has never seen a dyno, but it "feels" strong, to me, which is totally subjective. So, assuming that I did everything right, then those heads should flow much better than "stock" at the top end, right? Should I increase the size of the 2818's secondary mains "as a matter of course", because of the mods to the heads? Does the absence of symptoms signal the adequacy of the stock jetting, or will larger jets provide even more performance?
Joe
Joe
