Voltage reg part # - NCRS Discussion Boards
Voltage reg part #
  • Joseph K.
    • March 1, 1980
    • 168
    Voltage reg part #
    Found a voltage regulator in the garage the numbers on it are 1119, 511 and a date code of 8F. Also with it was a valve cover oil cap with AC Fe2 the middle rivet is in the shape of a shamrock(4 leaf) can any one tell me what these parts are off...........................Joe
  • Lyle24961
    Re: Voltage reg part #
    The oil cap is correct for a late 70's Corvette 350.
    • John D.
      • December 1, 1979
      • 5507
      Joe, I had a voltage regulator like that on my flea market table for years and a ton of Corvette guys looked at it. Finally some one bought it cheap. I said what is it for. He said Pontiac. Don't know if that's true or not. John D.
      • Joseph K.
        • March 1, 1980
        • 168
        Thank you all for the info..............Joe
          Yep, the '511 is for Pontiac (mirrored the '512 used for about 3/4-year on '63 alternator equiped Chevy's). It's wired differently and will NOT substitute for a Chevy '512 or '515 V-Reg...
          • Joseph K.
            • March 1, 1980
            • 168
            Thanks Jack, maybe I can find a home for now.......Joe
              • 43234
              Joe-----
              I think you'll find that the oil cap is "FC-2" and not "Fe2". AC oil cap FC-2 has VERY wide applicability over a period of MANY years. The configuration of this cap also changed a bit over the years, so I can't say from your description what period it is from. These were used on Chevrolet 6 cylinder engines from the 50's as well as 80's V-8s. The FC-2 was an oil cap of internal GM manufacture. Many other GM oil caps, including some which were sold in SERVICE to replace the FC-2 and others that were used in PRODUCTION, were of Stant manufacture.
              • Joseph K.
                • March 1, 1980
                • 168
                Your right on Joe....................FC-2 Thanks for your input..............Joe
