F.I. high pressure pump seal - NCRS Discussion Boards
  • mike yirak
    I'm installing a new seal in the gear pump. The book says to apply a good sealing compound to the outer diameter of the seal. Does anyone have a favorite sealing compound for this spot? Preferrably something on the shelf at 7-11. Thanks, MHY
  • Paul Y.
    • September 30, 1982
    • 570
    Re: F.I. high pressure pump seal
    Mike,
    I use silicone sealer in this area. I think the old time guys used permatex which is more difficult to remove. Paul Young
    It's a good life!
    • John D.
      • December 1, 1979
      • 5507
      Hi Mike, Being an old timer as my fried Paul say, I use Permatex Aviation Form-a-gasket sealant liguid part no. 3H which is available at most any auto store. Let it set up a couple of days before installing and adding gas. Be careful what kind of gas you use. "Corn" fuel will trash the seal. Unfortunately we don't have a seal for the midwest fuel. If so I would certainly like to know about it. John
