Oil filter adapter?? - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    Hey, I know this may sound like a stupid question but...is there suposed to be an gasket between the oil filter adapter and the block? I always thought it was a machine fit?? Terry
    • 43232
    Re: Oil filter adapter??
    Terry-----
    Assuming that you're talking about the 68-82 adapter, there is NO gasket between the adapter and the block----it's "metal-to-metal".
    • Terry F.
      • 2061
      Thats what I thought. Thanks Joe! *NM*
      • Kurt B.
        • July 31, 1996
        • 971
        What oil filter adaptor?
        I do not have an adaptor on my 68 smallblock?
        I never heard about adaptors for 68s before. I thought this only applied to earlier year cars so that they could be adapted to use spin on filters.
        Is this something used on big blocks only?
        Someone educate me please.
        Kurt
        • Clem Z.
          • January 1, 2006
          • 9427
          it is the aluminum casting that bolts to the
          block that contains the oil filter bypass valve and the threaded extension the oil filter screws on to. it is used on both SBC and BBC. casting # 3952302
            • 43232
            Re: it is the aluminum casting that bolts to the
            clem and Kurt-----
            Yup, that's it. The official GM terminology for this piece is ADAPTER. Curiously, the "equivalent" piece for 1956-67 engines was, in official GM parlance, referred to as a VALVE. BOTH the 56-67 and 68+ pieces do contain a bypass valve.
            The GM #3952301 (casting 3952302, as clem mentions) adapter (or its predecessor piece GM #3916328 used for 1968-only) were used for ALL 1968-91 Corvette engines, small block and big block alike, with ONE exception. The exception? 1969 with ZL-1.
