C2 power window conduits - NCRS Discussion Boards
  • Scott Marzahl
    Does anyone know if there are mulitple vendors for the reproduction C2 power window conduits? I bought a set from one major vendor and the curves are bent too tight and do not fit, therefore I'm trying to find another set that fits.
    Thanks for any leads.
  • Michael M.
    • November 1, 2001
    • 411
    Re: C2 power window conduits
    Hi Scott, I have been through the same thing. I have bought NOS, repops, and used original and they all had the same problem rubbing. I have positioned them everyway in the world and finally had to compromise to get the least rubbing as possible. I have had the doors on and off a dozen times to try and overcome this. I finally setteled with the least rubbing position and installed with small bolts and locknuts rather than the tapping screws and they seem to hold just fine even with the slight rubbing. Good luck with yours!
    • Scott Marzahl
      Thank you for this great insight Mike. I started searching all over for some used ones yesterday with no luck, so I guess I can stop that and just work with these.
      Scott
