70 LT 1 Q's - NCRS Discussion Boards
70 LT 1 Q's
  • Dennis D.
    • March 1, 2000
    • 1071
    70 LT 1 Q's
    I believe 1970 LT1's didn't have power steering. Correct? Also believe the 1100884 alt was used. Anyone know of the 1100542 application? Don't think LT1. Little long distance research.
  • Dennis D.
    • March 1, 2000
    • 1071
    Re: 70 LT 1 Q's
    Can anyone make out the last letter in the date code?
      • 43231
      Re: 70 LT 1 Q's
      Dennis-----
      Early 1970 LT-1 engiens were equipped with "6 quart" oil pans. None of those could have had power steering. Later 1970 went to the "5 quart" oil pan and I believe that this was done expressly for the purpose of making power steering available.
      GM #1100884 was the alternator used for 1970 Corvettes with LT-1, among other applications.
      GM #1100542 is a 63 amp alternator used for some 1973 model Chevrolets, but not Corvette.
      • Dennis D.
        • March 1, 2000
        • 1071
        Re: 70 LT 1 Q's
        Joe
        When in the year would you expect to see a 5 qt LT1 pan?
        Anyone with a 5 qt pan in a 70 LT1? Date?
        • Dave S.
          • August 31, 1992
          • 2925
          Re: 70 LT 1 Q's
          Dennis,
          My 1970 #14803 is an LT-1 with a 5 quart pan.
          • Dennis D.
            • March 1, 2000
            • 1071
            Re: 70 LT 1 Q's
            Dave,
            Puts you about a month later than my 6/16?
              • 43231
              Re: 70 LT 1 Q's
              Dennis------
              I believe that the earlier "6 quart" pan engines had the "CTU" engine suffix code and later "5 quart" pan engines were "CTK".
              • Warren F.
                • December 1, 1987
                • 1516
                Re: 70 LT 1 Q's
                Dennis,
                Looks like the letter B for close ratio M21.
                • Dave S.
                  • August 31, 1992
                  • 2925
                  Re: 70 LT 1 Q's
                  Dennis/Joe,
                  My #14803 is a "CTK" motor. If my memory serves me right the change over occurred in the #5000 - #6000 range. I believe the 70/72 TIM & JG adresses this.
                  • Gregory G.
                    • July 31, 2001
                    • 203
                    Re: 70 LT 1 Q's
                    My #1799 is a 6 quart oil pan with CTU designation.
                    • Dennis D.
                      • March 1, 2000
                      • 1071
                      Re: 70 LT 1 Q's
                      Found a march 7 LT1 with PS.(5 qt) No engine code ID though
                        • 15605
                        Re: 70 LT 1 answers are in the TIM&JG as
                        well as a story some years back (pre-1999) in The Restorer. Unfortunately, I have access to neither here in San Antonio.
