i was told when i went to GM carb tech classes - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    the reason for the thread damage was the fact that the threads were the lowest part in the carb and the water got to them. that is why as i explained above they changed the location of the sealing washer to prevent the water from getting to the threads. i have seen if the threaded areas of the float bowl were damaged the area inside past the needle/seat was OK
