Amp gauge - NCRS Discussion Boards
Amp gauge
  • John O.
    • May 31, 1998
    • 480
    Amp gauge
    Hi all.
    The other day when I had a mechanic friend helping me with my steering on my 1962 corvette, he noticed as I did that the Amp gauge is bouncing around when you start the engine.He said the wires on the gauge are on backwards. I showed him on the wiring diagram that the way I have them is the way the diagram shows. But he says the diagram is wrong. Is he correct? If I reverse the wires,can I do any damage to the gauge? I'm still working out a few bugs.
    Thanks............John
  • Donald L.
    • September 30, 1998
    • 461
    Re: Amp gauge
    If the diagram youre using is the original then its backwards. The diagram that Don Olson makes is correct.
    • John O.
      • May 31, 1998
      • 480
      Re: Amp gauge
      Thanks Don
      It's the diagram that came with the Lectric Limited wire harness.
      John
      • Mike E.
        • February 28, 1975
        • 5139
        Re: Amp gauge
        Look in the AIM, the owners manual, or the ST-12. All are wrong.
        • Donald O.
          • May 31, 1990
          • 1591
          Re: Amp gauge
          Thanks Don. You have no idea how many people ask me why my drawings are different from LL.
          Don
