I have recently been restoring my radiator, support and fitting electric fans. Also bought a fresh set of seals. They were from an ebay supplier, but I think they originally came from Dr. Rebuild.
I'm having some trouble working out exactly where they are supposed to fit. The AIM is sketchy at best, which is a problem because this is about the best information I have. Many of my original seals were missing, so I don't have much to go on.
Does anyone out there with a very original 80 have any pictures or advice about how these things fitted, out of the factory?
There are some seals which are obvious: the two long vertical ones down the sides of the rad, the two dog-leg ones that fit over the hood hinges between the hood and the top corners of the rad support, and the two pieces that go either side of the cold air snorkel.
The ones that are puzzling me are a long strip about 18 inches long that is supposed to go somewhere in the upper middle of the rad support, and two other short, brick-shaped pieces that go somewhere near the top radiator brackets.
Anybody??
Thanks!
Theo
Anybody??
Thanks!
Theo
