C2 Brake Bleeding - NCRS Discussion Boards
C2 Brake Bleeding
  • Ken Harants
    C2 Brake Bleeding
    I am in the process of bleeding my brakes. Since I have knock offs I want to make sure I do it right the first time. The only thing I am not sure of on the rear calipers where you have two bleeders, does it matter which one you start with first, inboard or outboard. I am starting with the rt rear then the lt rear rt front and lt front.
    Re: C2 Brake Bleeding
    Ken -
    Many folks recommend bleeding the inboard side first, then the outboard side.
    • Eugene B.
      • May 31, 1988
      • 710
      Ken,
      In addition to what John said. The '65 shop manual suggests that: "Tapping of the caliper with a rawhide mallet may assit in obtaining a good bleeding job."
      Don't know whether this is good technical advice or a method of driving away evil spirits!
      Good luck with your brake bleeding project.
      Gene
