C2 1967 327 YZ or YS Engine Code Suffix - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2134
    Working from memory here, which is risky at best.
    Seems I recently saw a 1967 Casting date on a 327 block, and the Engine Suffix code was YS or YZ. Mr. Colvin does not list. Any thoughts on this?
    I can dig up the casting number if needed.
    Thanks in advance.
    Tom Dingman
    4889
    Michigan Chapter Site (Link)
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • 43221
    Re: C2 1967 327 YZ or YS Engine Code Suffix
    Tom------
    Yes, I have a thought. Engine suffix code "YS" was used for 327 cid/220 hp engines installed in some 1966-68 Chevrolet trucks. So, an engine could easily have a 1967 casting date and 327 casting number with a "YS" code. It was never originally installed in a Corvette or other passenger car, though.
    • Tom D.
      • 2134
      Thank You Sir. *NM*
      Michigan Chapter
      Tom Dingman
      • H S.
        • August 31, 1994
        • 36
        Re: Thank You Sir.
        Tom,
        You may be talking about one of the blocks in my shop that you seen on one of your visits. One of them is a 657 with a cast date of B 6 7 and stamped V0214YS and I definately pulled it from a one owner 67 pick up truck. Have accumulated some more "interesting stuff". Commimg this way anytime soon?
        H P
